Author Topic: MusicBee 3.1.6466 won't open in Windows 10 1709  (Read 8956 times)
mondro
Just as it states. Musicbee will install just fine and launch after install. However after you close it, it will not launch again.This is a fresh install of both musicbee and windows.
please use the forum search function as this has already been raised and answered
DesertRobot111
I'm going through the forums right now trying to find the answer. If you find it can you link it?
DesertRobot111
Found it;
Windows 1709
mondro
Try with your security app disabled (including Windows Defender). If that's the cause, try whitelisting MB.
mondro
Whitelisting worked. However I am now having the issue of scanning my library/it hangs with one track to go?
Try with latest patch as some bugs have been fixed. Unzip and overwrite to your MB program folder:
If that doesn't help, maybe the file is just a corrupt one.
