Author Topic: Audio files on mapped drive, playback sometimes stops at the end..  (Read 1459 times)
theG
I have all my music on a mapped drive under Windows 10, and sometimes playback stops at the end of the song.
I'm guessing it has something to do with the tracks fading into each other, maybe..
I have "crossfade tracks" set to 3 seconds, "fade in new tracks" is ticked, as well as "remove silence at start and end of each track".
It seems random. If I listen to an album, the first time it could happen to track 2, 3 and 7 for instance and if I listen to the album again it could happen to track 1, 3, 4 for instance.. It just seems random.
When playback stops, it's just like if I pressed pause; the PAUSE button becomes a PLAY icon.
I started using a mapped drive about a year ago and for as long as I remember, it always did that. I update to the latest 3.1 patch every 3 weeks or so.
Here's what the end of the wavebar looks like when playback stops. As you can see, it doesn't stop at the very end.
if you are playing .m4a files then get bass_aac.dll - see the FAQ in the wiki
otherwise the obvious think to try is disabling the player options, especially the remove silence option
theG
They are FLAC files.
I understand the disabling of "remove silence" but doing so is just taking away a useful feature and not fixing the actual problem/bug...  :-\
if you establish that it is the remove silence setting then i will need one of the problem files so i can see what is going on
theG
I'll do some testing with different settings and report back to try and find the culprit.
I don't think it's a file specific problem since I have 166,000 FLAC files and it's been doing that routinely..
