Author Topic: "app"-function for uTorrent 2.2  (Read 3494 times)
Self-elegy
In uTorrent 2.2 there is this new "app" function with a list of applications that can be used with the uTorrent software. VLC media player, for example, has this function. When a movie, or when music is downloaded you can choose to let VLC "scan all your torrents" and allow it to open your file directly.
I was wondering if - instead of just playing it directly in MB - one could choose to "sync" or integrate newly downloaded songs to the MB library directly from a uTorrent-app.
allforcarrie
add your download directory to your watched folder list.
ferongr
A nice workflow regarding working with album from torrents:
1: Set the music download location in a dedicated directory separate from other files.
2: Add this directory to the scanned directories in MB, and select "Add to Inbox" for new files
3: Enable auto-organization.
3: As torrents finish, select "Rescan" from the "file" menu.
4: In the now populated Inbox, apply RG (if you want) and afterwards bring up the Album Tagger. Once you select the correct album release to tag the files, press "Apply in the Album Tagger
5: Your files should be integrated in your main library directory with consistent directory/filename values from the tags. The files are subsequently removed from the inbox.
