Author Topic: ipod copying error  (Read 2514 times)
Dpmusicbee
hi,
i'm getting this error qhwn i try to copy a song to my ipod touch
MusicBee v3.1.6483.18457 (Win10.0), 3 Oct 2017 12:23:
System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'iTunesLib.IITIPodSource'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{CF4D8ACE-1720-4FB9-B0AE-9877249E89B0}' failed due to the following error: The application called an interface that was marshalled for a different thread. (Exception from HRESULT: 0x8001010E (RPC_E_WRONG_THREAD)).
   at System.StubHelpers.StubHelpers.GetCOMIPFromRCW(Object objSrc, IntPtr pCPCMD, IntPtr& ppTarget, Boolean& pfNeedsRelease)
   at iTunesLib.IITIPodSource.EjectIPod()
   at MusicBeePlugin.ITunes.Close()
   at MusicBeePlugin.Plugin.Eject()
   at MusicBeePlugin.Plugin.turnOnEventHandler(Object sender, EventArgs e)
   at #=qCYuNPT_pkZhe0BeFvIdrtDcD9U14COGMhEp_wsrpbXKwvnoLUJ9O7I4OR5YKlOxE.#=qJM2HaHQijqTIWfl_v6bREw==(Object #=qrWLIx4rXF2vsyok91tDgrg==, EventArgs #=qPti0zT4oJ59mbeYe4wv8sg==)
i was able to copy songs earlier but now i can't. please help i learned that you have to turn on your ipod each time you wih to copy songs.
Thank You
Dpmusicbee
The issue is with the ipod plugin, so it needs to be reported on that topic.
However the plugin author hasnt been active on the forum for a while and i also vaguely recall him saying he no longer supports this plugin
Dpmusicbee
ok so how can this be resolved please? is there no plug in to fix this.
Did you see what Steven wrote?
Did you report it in the thread for the plugin?
Unless someone is willing to take over the plugin -and- can get in touch with the plugin author to obtain the code, the plugin is dead.
Last Edit: October 04, 2017, 02:21:49 PM by phred
