Author Topic: mb "freezing" prob  (Read 5293 times)
leevancleef
which version are you using (in help/ about) ?
also it would be useful if you were able to send me a link to a zip of one of the files that had this problem
[/quote]
It happened to me on two versions: the first one I downloaded about a month ago and the one I'm currently using, which is 3.1.6466. Unfortunately, I don't remember any of the specific tracks it happened with, but I still haven't had an issue since I unchecked the "remove silence" option.
EDIT: I've started using the .mp4 format over the last year or so, and I'm pretty sure that's what it was freezing on. I noticed in a similar thread that there may be a fix for that, so I'll check for that .dll file in the FAQ section.
Last Edit: October 19, 2017, 07:36:07 PM by leevancleef
definitely use bass_aac.dll as the windows 10 aac encoder can cause problems with the bass library for some files
eddi
  • Writer / Music Blog / MusicBee Power User
@Steven hey thanks for your constant attention
i´m reading all of the entries here.
i´m running the microsoft defender on a win 10 32 bit system
i haven´t noticed any problems with the defender but of course i can whitelist musicbee
i´m planning to clean install the latest win10 creaters update (1709) and also the latest 3.1 full setup + the latest update 3.1.6497+
maybe this will help .
something that i noticed that might be a problem is that i´m using jpg files for the cover artwork and png files for the artist pics.
i was scanning the cover folder and there were a lot of png files.
the png files are bigger and make musibee load a lot longer. or is that somethang that usually happens  when there are 5000+ files to be provided?
things were ok for a few days
thx in advance eddi
