Author Topic: Cursor don't follow current title  (Read 2415 times)
Babydoll32
I got the issue, that the cursor won't follow the current title, since I installed V3.1.6466  :(
Version 3.0.6335 worked fine...
I don't think, I've wrong settings, used the same as in previous version (cursor follows, sync panels etc.). Had also done a clear reinstallation, but nothing worked  :-\
Working fine here and not something i recall touching.
Can you post a screenshot of your setup and indicate which panel you are using to select the next track; or perhaps you are saying if you dont select the next track MB is not playing the next one following the current track in sequence automatically?
Babydoll32
Hi, Steven.
Below my screenshots.
On first one, you see another track highlighted, than played.
The last screenshot is taken from the previous version, where everything works fine.
Screen 2 & 3 are my settings. Don't know, what's wrong.
I used shortcut and buttons, to jump between tracks, like in previous version.
can you send me a link to your settings file (help/ support/ view settings)
Babydoll32
Hi, Steven.
Sure I can do. But I've trouble with my Internet provider, since sunday. At the moment, I can only use my ugly mobile connection for this answer. Hope that they work on this problem and repair my connection soon.
Best regards
Norman
Babydoll32
Good morning Steven
Got a connection at the moment.
Here are my settings:
MusicBee3Settings.ini
i cant reproduce any issues using your settings but in the course of investigating i did find a couple of different bugs related to this setting.
Its possible the issue has already been fixed
unzip and replace the existing musicbee application files.
If you think its still not fixed then I suspect you have a different understanding of how this function works
Babydoll32
Hm,
patch didn't fix it.
I also compared both installations and didn't found differences between settings  :-\
My problem is, that the editor window won't follow the current title.
i.E. I start playing "Born in the U.S.A.", the tag editor shows "Born in the U.S.A.".
Now I jump to next title "I'm On Fire" by shortcut or using button and tag editor still showing "Born in the U.S.A.".
Tag editor in previous version was following current title  :(
I think I'll further use the old version for the moment.
Babydoll32
Hi, Steven.
I found out, where the "issue" is/was.
I tapped the next title button in seperate editor window.
After I did, I integrated editor in main window and editor followed the actually played song  :)
Best regards
