Author Topic: MusicBee's window is not minimized even if click on the taskbar button  (Read 2032 times)
nishi2x4
When the MusicBee's window is in the foreground, even if you left-click on the MusicBee's taskbar button, the window is not minimized like other applications.
MusicBee 3.1.6466
Options are all default
Windows 7 64bit
This problem did not occur MusicBee v2.5.5804 or lower.
This problem occurred in Version 3 or later, which continues until v3.1.6466.
working fine here. Can you post a screenshot of the Preferences/ General panel
nishi2x4
I found that this problem happens when Windows Aero is disabled and MusicBee version is 3 or later.
In v2.5.5804 or lower, even if you disable Windows Aero, clicking the taskbar button minimizes the window normally.
I have not changed Preferences in either case. It remains the default setting.
its not easy for me to test with windows 7 anymore and this doesnt seem an issue that would affect many people so i will leave it unsolved
nishi2x4
ThomasV
I can confirm this behaviour,
using the mobile version (3.1.6466) in Windows 7.
Interestingly enough, I had to restart Musicbee after enabling Aero to make it work.
Ricky Roma
Hey nishi2x4,
Did you ever find a solution to this? I have the exact same problem. I know it's not a major deal, but it is habitual to simply left click a taskbar icon to minimize and Musicbee is the only app on my PC that won't do it.
TIA
