Author Topic: How to enable MusicBee to run up to 4GB of memory (System.OutOfMemoryException)  (Read 38342 times)
jpirez
Despite successfully patched I still get the Out of memory error
MusicBee v3.4.8033.18564D  (Win10.0), 30 Dec 2021 13:00:
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
   at System.Threading.Thread.StartInternal(IPrincipal principal, StackCrawlMark& stackMark)
   at System.Threading.Thread.Start(StackCrawlMark& stackMark)
   at System.Threading.Thread.Start()
   at #=z9xpOhZZF8416QDRVkDgFBYAbLk3$.#=znsOQyRbFtCjCYQqXXzOi7h8=(Object #=z09rm0$E=, EventArgs #=z5EKpxKY=)
   at System.Windows.Forms.ToolStripDropDownItem.OnDropDownShow(EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnDropDownShow(EventArgs e)
   at System.Windows.Forms.ToolStripDropDownItem.ShowDropDownInternal()
   at System.Windows.Forms.ToolStripDropDownItem.ShowDropDown(Boolean mousePush)
   at System.Windows.Forms.ToolStripMenuItem.OnMenuAutoExpand()
   at System.Windows.Forms.MenuTimer.OnTick(Object sender, EventArgs e)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
Just to be sure, did you happen to apply a MusicBee update patch AFTER successfully updating the original version to LARGEADDRESSAWARE?  The process needs to be re-run every time the exe is updated.
jpirez
I just applied the  LARGEADDRESSAWARE patch as per instructions, and I still have the same problem.
jpirez
Yes, it can handle LAA.
This problem only started when I moved to Windows 11
FILE HEADER VALUES
             14C machine (x86)
               3 number of sections
        61CB9B9D time date stamp Tue Dec 28 23:19:57 2021
               0 file pointer to symbol table
               0 number of symbols
              E0 size of optional header
             12E characteristics
                   Executable
                   Line numbers stripped
                   Symbols stripped
                   Application can handle large (>2GB) addresses
                   32 bit word machine
