Author Topic: save current playlist as a file  (Read 3682 times)
Nihilismus
Hi there, was wondering if there is an option to save the songs I put into the "Playing Tracks" sidebar as a m3u file or something
andrew
1.open a new and empty playlist
2. click top song > hold shift button > click bottom song
3. drag selected songs to the empty playlist
4. right click playlist and export.
Nihilismus
Now that's a hassle, would be a lot easier if I could just hit control + s. This makes replacing playlist a lot harder than it should be.
You can also select all in Playing Tracks, then right click and choose Add to Playlist > External Playlist.
Edit: corrected because I had it wrong at first.
I don't think External Playlist will be automatically added t your library (unless you're saving it in a monitored folder), but you can always do the same thing a second time, choosing New Playlist
Last Edit: September 09, 2017, 11:33:37 PM by psychoadept
Nihilismus
Is it to late to suggest changes? Because it would really help if there was a easier way to make playlists. I can control+a and send all to a new playlist, but I like to create one for every month and then replace it everytime
You can always make a wishlist request.
alec.tron
You can also setup musicbee so it exports all playlists inside of MB as m3u files to an additional location of your choosing...
In my book that's better & easier than ctrl+s plus typing name every time...  :D
c.
andrew
whole process takes about 20 seconds mate.
