There is a new setting required to be ticked in the Tags(2) preferences
Thank you Steven : sorry to have bothered you instead of seeking potential new settings.
I also face another problem (and will open a new topic if you think it's necessary) : the Eric Milles airplay plugin does not work any longer. The following error is displayed when I try to select an output device :
MusicBee v3.1.6454.19233 (Win10.0), 8 sept. 2017 19:09:
#=qpr$Ap88IZeTjU7Wi4cnW1j4n6kII7vO1ICkJ9Aah4hs=: Unable to initialise sound device
à #=qm$hjy6x9U3gcPhkZS1klCKphG$qHK00ml2Y3VMFaeDs=.#=q0$l7rTuT9Qn9OLkw8u7g2Q==(#=qXqWCjVKtXEzOEKmQLL121YSpMrcFWigYIH9mhwNQ3Ho= #=qB3qL8YRjGsl8jRHRvnB7Xw==, String #=qLC9Ak5cry0fROzUNt7__sd1DxBlJjXgS7gYaygWFspM=, #=qkBZgVZeUsyzvEEjOUPtyHw== #=qaUWEMqLDKO23PUEuFH2Cqxm7wMb4h7e_vk7gEde9MVg=, Int32 #=qVpadl1XT8QELMnbmhNqO1A==, String #=qI5z_mCpXQkPbRvLopgLdPA==, IntPtr #=qqaSHv6hj4rgvVCsYA10w1g==)
à #=qWKC9WP_wHOzS3LXdIueUApF1NuPhHV2zzo76PzSgmC2UA3jBJsI9M56roQX1hd2o.#=q91zo1kh91KK7v5FRpjy6JcNKIAohLRroofzFSHZE0gY=()
à #=qWKC9WP_wHOzS3LXdIueUApF1NuPhHV2zzo76PzSgmC2UA3jBJsI9M56roQX1hd2o.#=qhHmLHIuoSMV8vY5FON4cXoDeGhzih$hDO8eN0wpRvbg=(Object #=q1lJ5rIsCKEvI8H$es2nPFA==, EventArgs #=qPe5NK7Z7Hh$IEcfWOhJl8w==)
à System.Windows.Forms.Control.OnClick(EventArgs e)
à #=qzxr6mm_lMlQaaOdSKDnhOhIleupvV07esUt7b1akjf0=.OnClick(EventArgs #=q0n$btExb1sLBBSBnklPxAQ==)
à System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Do you know how to account for it ?
Thank you very much in advance for your help.
