Author Topic: Normalizing OGG files while syncing  (Read 957 times)
Babydoll32
Hi, maybe I'm too dumb and solution is simple. My music is stored as FLAC. I would like to sync my USB with OGG for my car. That works so far, but I need to normalize the OGG files in pre-processing, like Foobar2k can do, cause my car-audio isn't able to work with post-processing replaygain tags. Is there a way to realise it by musicbee syncing? Otherwise I need to use Foobar2k further, to fill my stick.
in the device sync settings panel just tick "level volume" and when converted to ogg, the volume level will be adjusted without the use of tags
