Author Topic: Album Types (LP's ; EP's ; Singles ; Compilations, etc.)  (Read 121642 times)
The Incredible Boom Boom
I'm using the method where the "Group By" section is using the virtual tag that is blank, so in sub-grouping i'm using the virtual tag that really sorts the grouping in the way i want., also the custom sort that i'm using is: Grouping/ Year (Desc)/ Album
I'm not sure I understand what you're trying to say here. Can you clarify it?
aktor
In music explorer when you group by virtual tag you can make it blank when the tag has no value with this formula for example $IsNull(<Grouping>," ",<Grouping>) but the blank space remains. As i to don't like empty space I have set it so it displays "albums "with with some ornaments when it isn't an Ep, Single etc... I would very much prefer the option with no emtpy space.
•―――•  ۞•――――•      $IsNull(<Grouping>,"  A  l  b  u  m  s  ",<Grouping>)      •――――――•  ۞•―――――•
dalesmedley1990
Any chance of getting all this put into an easy to follow step-by-step tutorial or as a plugin or something?
audioscience
SUCCESS
It's too bad we can't make the headers bigger. I'm going to make a wishlish post to see if Steven can make this all a but more simpler by adding better ordering support for groupings
Nevermind, I was doing it slightly wrong- Have it working at 100% as intended!
Wow! Can this be done under the Album Artist view?
You can split the Album Artist view to the right and it will appear like that.
You would set this up in Layout under the Preferences.
  • MB Version: 3.6.9255 P
Not sure you could do it the same as Sub Grouping is not available in Artists view.
audioscience
I tried looking for this setting, but uhm, can't seem to find how to split the Album Artist view to the right.
Help please? :)
Help please? :)
In Preferences -> Layout (1) -> main panel, you'll look for the "show the tracks for the selected album or artist"... option.
audioscience
I still can't seem to find the correct setting for this, but I have somehow chanced upon an easier way of doing this
This works for both Album Artist and Artist views
1. Set the "Groupings" tag to your preferred labels
2. Click the "Configure Layout" button on the upper right of MusicBee (see screenshot below)
3. Under "Main Panel > Group By > Grouping"
4. Check "Show Header in a Separate Row
And that's it! Simple as that.
My only concern now is setting the Groupings label on the Main Panel to my preferred arrangement--as I would really like the Studio Albums to show first, then EPs, Live Albums, then Singles, and Bootlegs. But it seems to sort alphabetically.
You are using the Music Explorer view (not the Artists view as you said earlier) that has different set of sorting/grouping behaviour than the Artwork view that this guide was written for, but I'm glad you where able to get it working to suit your needs.
This is where you'll have to get creative with some zero-width-space (ZWS) characters in your grouping tag to overcome the alphbetical sorting
Last Edit: January 09, 2024, 11:02:20 PM by Bee-liever
For anyone running into this thread and wanting to create a non-alphabetical custom sort for things like 'Studio Albums', 'Live albums', 'EPs', 'Singles' etc.,
MusicBee now has a dedicated feature for this. (MB version 3.6.9153 and up), so the 'zero-width spaces trick' is no longer needed.
See here for a great explanation on how to use it by forum member tjinc.
