Author Topic: Album Types (LP's ; EP's ; Singles ; Compilations, etc.)  (Read 125269 times)
The groupings will be in alphabetical order. So if you want a specific order, set them like 1. Albums, 2. EPs, 3. Singles, etc
DiscgraBee
What is Yo's skin in the OP?
Last Edit: November 10, 2019, 02:54:18 PM by johnmillsjr
  • MB Version: 3.6.9318P
I think it's Aurora
Corliss Rain
First of all, thank you to the OP because I loved this idea and have started incorporating it into my library with a custom tag. Looking for advice on something, though. How would you label albums where the artist has re-recorded older material due to label and copyright disputes? Pondering "Re-Recordings" or "New Recordings", but neither one feels right to me. (Yes, I'm being a bit OCD.) Thoughts?
DiscgraBee
Bee-liever, I can see you have achieved something that I haven't been able to.
I see you use the year tag the same way as me, in the format 03/04/2016.
My albums doesn't get sorted correctly this way though.
But I see you have made a custom tag named "Release Sort Index".
Well, I haven't had any success creating a custom tag for that purpose.
I would appreciate any tips on how to do it.
Thanks!
"Release Sort Index" is the date in reverse order. 03/04/2016 becomes 20160403.
I find it especially useful with older releases where you can sometimes track down the month but not the day of a release.
You can only put a year into the year tag with that but with "Release Sort Index" I can also use the month. eg. 19420400.
One of these days I'm going to work out how I can enter the date in ISO 8601 format (YYYY-MM-DD) and get the Additional Tagging Tools plugin to automatically fill in both the "Year" and "Release Sort Index" tags!
Can you sort tracks in Album Covers view by this?
Certainly can.
I currently use Album Artist/ Group Sorting/ Release Sort Index
DiscgraBee
Certainly can.
Do you set up realease sort index as a Custom Tag?
I don't see it in the Sorting Set drop-down menus
Certainly can.
Yep, it's a custom tag.
Details in my reply to ChristoMorse you quoted earlier.
Thanks!
DiscgraBee
You can set it as 'release time', no problems  :)
It doesn't really matter what you call your custom tag, as long it's easy to remember what your putting in the tag and the name doesn't conflict with existing tags.
DiscgraBee
can you add a final 2 numbers for track and have it sort all songs via that whole number within an album?
Not sure what you mean. Could you explain a bit more please.
DiscgraBee
So in Ellingtonia (a duke ellington discography) each recording has an index number which has the date formatted the same way as release sort index.
Then it has 2 final digits denoting the track order of that recording date/session. ie YYYYMMDDRO (RO=Recording Order ie. 01,02,03...)
If I use the same method will it order correctly?
DiscgraBee
Also, if we make groupings such as
1. Boxset
2. LP
3. Live
etc
If they're not quite alphabetical as with LP then Live is there a way to hide the ordering number in album covers view?
You might be able to do something with a virtual tag that removes the numbers
