Author Topic: Album Types (LP's ; EP's ; Singles ; Compilations, etc.)  (Read 98560 times)
wobbly
thank you for adding this  I donated again hope we get a link soon  :) great work
wobbly
just wondering if this is done yet can not seen to find it as of 3.2.6542 was going to test it out  and give feed back .. thank you
It's already there in Customize panel dialog for Album & Tracks view.
It's Artwork view button> Group by> Sub Grouping
Last Edit: December 03, 2017, 01:18:31 PM by redwing
wobbly
i  still can not  get this worked  out  i have some albums  done for testing using grouping  tag
with
Studio
Compilation
Live
and so on
 read Reply #6  and still lost
get  stuck here "you can then use a custom sorting" where to do this?
Last Edit: December 04, 2017, 04:23:52 AM by wobbly
You mean where to define custom sorting set? Look at the second picture that shows Sort by> "Define custom sorting" menu at the bottom.
wobbly
yes i see Define custom sorting"   but how to set this up coun't see how to name it or anything
Just click on an empty box, then you can choose fields and its order that becomes its name.
wobbly
oh ok  thank you will try in the morning
Last Edit: December 05, 2017, 06:40:11 AM by wobbly
wobbly
ok getting there  i have picked up a few strange things
i dont know if it's  a bug or if i'm doing something wrong
have all Dave Edmunds albums grouping with Live : Compilation and so on that's great
but
seeing all Various Artists albums  that  have Dave Edmunds on them
if i click any of the   Various Artists albums  it just plays the full album
and not only the  Dave Edmunds tracks
1 or 2  would be fine
1 is there a way not to show Various Artists albums
2 or only show tracks by the Artists  on  Various Artists albums (eg Dave Edmunds)
ps all the Various Artists albums are unknown grouping atm if that helps
Last Edit: December 04, 2017, 11:13:55 PM by wobbly
Try artist for group by field and grouping for sub grouping field.
Then it will show only the artist's tracks in various artists albums.
wobbly
ok i needed  to quit music bee  seems  to be working now  strange
wobbly
wobbly
ok if i use grouping tag   i get strange things happening
but if i use custom 1 name album type all works fine
Last Edit: December 05, 2017, 06:25:44 AM by wobbly
I mentioned the grouping tag simply because you said you're testing with the tag. You could use any tag.
But I have no problem with grouping tag.
wobbly
i would like to use grouping tag as it is a standard tag but can't work out what the problem is
 i wish musicbee had lots of video tutorials on how to get things done under the hood
