Heya,
relaying this:
Since Musicbee seems to be relying on unique names when it comes to playlists & folders, would be great if there was a warning when non-unique playlist/folder names are detected !
(in my extreme case that might be a bit tricky as I do rarely but occasionally do extreme edits to the organizational structure in file system directly as well, and let MB just read the resulting folder/m3u hierarchies... )
As well as throwing an error when a playlist can not be written (ideally with some indication as to why it failed) as it has happened to me occasionally when there's 2 playlists with the same name as this stops the m3u as well as itunes xml write (without the user noticing, unless you double-check actively that the files have been written as expected).
From this old thread:
https://getmusicbee.com/forum/index.php?topic=17948.msg131344#msg131344Churs.
c.
