Author Topic: Mass Updating Play Counts and Date Added Help  (Read 1306 times)
musicplayer1234
I have an itunes xml file that has play counts, date added, and skip counts for about 1500 songs. I was wondering how would I update the tags of the songs I have on musicbee with the xml file without changing the other songs in my musicbee library. So far I've been doing it manually, but that takes a long time.
Thanks in advance
main menu/ file/ library/ import/ import from iTunes
and you can choose to overwrite playcounts and ratings.
I suggest you take a backup of musicbeelibrary.mbl first. It should work but i havent looked at that function for years
