Author Topic: Scrolling Advice  (Read 2270 times)
Mobbsypom
Good morning all,
a quick question..
I occasionally want to add a file to the now playing list, but the speed that the list scrolls up and down is quite quick!
Appreciate that this is a first world problem..but any ideas as to how to slow the scroll speed down (is it an MB or Win 10 setting)
Thanks
  • MB Version: 3.6.9255 P
update to 3.1 version
you can then hold the alt key down while scolling to get a slower speed
Mobbsypom
Brilliant..currently on 3.1..now know what  to do!
Cheers
CritterMan
  • Now with FiiO M11!
Mobbsypom
Interestingly I found that after I had done that once, it remained at the slower scrolling speed..
thanks all for their help
