Author Topic: Clicking "next" arrow when editing tags auto-selects all tracks  (Read 1444 times)
thisisjohn
Sorry if this has been discussed some place else, I tried searching but couldn't find anything.
I had been on some version of 3.0 for a while (probably like a year-ish), but recently updated to the latest version of 3.1 (I didn't realize the program wouldn't proms me to update).
Ever since I updated, whenever I'm editing a tag for specific track, when I click either arrow at the bottom to continue to the next track, the window blinks for a second and then acts as if I selected the entire album. This is really annoying when I'm trying to edit information on song-specific details such as songwriter because I'm not able to just move on to the next track. Instead, I have to right click on each track to edit it.
Any help would be very much appreciated, thanks!
Can you post a screenshot of your layout, along with the tag editor being open. Also confirm you are editing files from the main panel
thisisjohn
In the first screenshot, I am editing the 3rd track, I add a "u" to the end of the title of the song.
http://imgur.com/aTwLxwj
In the second screenshot, after I click the right arrow, all the tracks in the album are selected.
http://imgur.com/vJbT0g4
As you can see I'm editing in a separate window. I actually didn't even know you can move the tag editor directly into the main panel. I tried that, and it seems to work fine.
Also, I realized today that if I'm editing in tracks from the "Inbox," the tag editor works like normal.
i still cant reproduce this, so could you send me a link to your settings file:
help/ support/ view settings
thisisjohn
https://drive.google.com/file/d/0B-v3zF6F6c7kMmN2TkZXcmZDemM/view?usp=sharing
And I actually tried editing in the main panel again (without the floating window) and it turns out I have the same problem as using the window. Let me know if the link works fine.
