Author Topic: additional buffer setting for wasapi (asio?) to solve some problems  (Read 16384 times)
rurutia10
Seems like they both enable the same outcome; small delay to stop music at the start from being cut off.
I don't use WASAPI though, mainly sticking with ASIO. I don't like having to fiddle around before I can hear sound from YouTube videos or other sources :o
Yes, you are right. In foobar, setting the buffer only solves it for wasapi, but activating the 'silence plugin' fixes it for both wasapi and asio.
Thanks, that's useful.
given its been confirmed this can be solved with a DSP, i will make a couple more attempts at this.
Its possible the bass function i am using is not doing what i think its doing, so i will make one more attempt after this if it doesnt work
https://www.mediafire.com/file/1gtbnfct3qd2f9p/MusicBee.zip
its hard-coded for 0.5 seconds. Even if it does work i wont include it in future v3.1 patch updates and will only officially include it in v3.2 via a configurable setting
This indeed fixes it for me. Both for wasapi event, and push mode.
(not for asio, but that's probably to be expected)
Thanks! I'll keep using this one until 3.2 gets released.
it should have worked for ASIO
I double-checked, and it doesn't work on asio for me. Only for wasapi.
(which is perfectly satisfactory for me personally)
Perhaps rurutia10 has other results with it?
Last Edit: October 09, 2017, 10:01:59 PM by hiccup
rurutia10
I now have this pre-silence tweak working with asio too.
When checking the asio output configuration settings, I noticed that by default all kind of surround channels were enabled.
I disabled all but Left and Right front, and now the audio isn't truncated for asio also anymore.
This might be device-specific, but I thought to share it anyway.
In regard to this thread, I noticed that un4seen has just released a revised basswasapi.dll (2.4.2) today, whose description says :
"Adds support for lower latency shared mode on Windows 10, more precise latency measurement, buffer size specification in samples, and notification of unexpected stoppages."
Steven, maybe this could be helpful in supplying the additional buffer settings you have been working with?
Well spotted.
I just tried this new dll (on a separate portable test installation), and it solves one of the problems I have been experiencing:
In wasapi mode, I couldn't skip within the playing track by using the progress- or wavebar, because then the playback would immediately freeze.
That seems to be resolved by using this new basswasapi.dll
But I am not advising anybody to do the same on their day-to-day MB installation.
I believe there is some finicky interaction between MusicBee and the basswasapi dll, so Steven probably will be needing to make some further adjustments and fine tuning of MusicBee's core to make it really solid.
But for now I am already happy that this will very likely make it possible to improve on MB's wasapi playback and buffering.
So thanks for reporting this sveakul!
i will include the new basswaspi going forward.
I dont see anything noted that should affect musicbee's handling nor fix any bugs but thats good news if it has fixed a mystery problem
Because of the buffer issue, I'll keep using the tweaked MB version you made available some five weeks ago. ( https://getmusicbee.com/forum/index.php?topic=22493.msg134648#msg134648 )
But for when 3.2 gets released, I'm keeping my fingers crossed that that will resolve both issues for me.
