Author Topic: Sample Skin  (Read 82692 times)
frogg3862
Reiterating: thank you for this! I've been tweaking a skin that I really like.
One of the final pieces I'm looking for is the sort arrow (ascending/descending):
I found line 115 of the Sample Skin:
<element id="Content[TrackDetail].Body.ListHeader" bg="240,254,253" bg2="240,254,253" fg="10,102,196" bdr="35,156,217" /> <!-- 79,177,225 auto-generated -->
But changing the `fg="10,102,196"` value there changes both the color of the column header text AND the sort arrow. Is there a more specific selector I can use to give that arrow a unique color?
Last Edit: January 26, 2023, 06:00:50 PM by frogg3862
Welcome to the forum frogg3862.
I am pretty sure there isn't an element for that.
So you could put out a request for it.
But be aware there are several locations where these sorting arrows can appear, so that will then probably need to be looked at too.
Last Edit: January 28, 2023, 07:41:48 AM by hiccup
karbock
(1) Great tool!
(2) I've stumbled on a really tricky colour issue, which is only visible when the player controls are docked at the top:
a black line above the track title (1-px thick, rgb=0,0,0).
Zoomed capture showing the line with "Sample Skin.xml":
It is striking with skins using lighter tones, such as Cheetah DNA:
The black line doesn't top the whole rectangle containing (tile+time+progress bar), but only the part used to display the track title.
The artefact shows up with a series of .XML I've tested:
  • Absolute Zero
  • AeroBee
  • Midnight
  • Phred on the lookout
  • Sky Blue
  • Threshold flat
  • Cheetah DNA
  • Chameleon DNA
  • Blue
  • iBee
With skin "MusicBee3", it is visible with both the .XML and .XMLC.
I haven't found any setting explaining this so far
* in RotemK's guide
* in the wiki
* when browsing through the .XML files (especially the PlayerTopFlat and PlayerFlat settings).
Any idea of the possible cause?
what font and font size are you using in the player panel?
also what dpi scale is used for the monitor
Last Edit: May 08, 2024, 11:59:55 AM by Steven
karbock
Font Literata, bold italic 18
Windows scaling 100%
The font is available here:
https://fonts.google.com/specimen/Literata
ok, its a MB bug when you use a large font for the default font. I will look to fix it
karbock
So maybe I should add a comment element to the Sample Skin that says: "file a bug report" when RGB "0,0,0"is picked?  ;-)
karbock
Well, when I posted, I wasn't 100% sure that it was a bug, since while testing I had come across one (and only one) .XML without the issue: ProTunes.
I was still trying to find what difference between SampleSkin and ProTunes could cause it.
I have extracted lists of the IDs present in either file (pruned of their parameters and sorted), if you are interested.
A tool like KDiff3 can highlight the differences, example:
Last Edit: May 09, 2024, 11:49:01 AM by karbock
I can't replicate this to begin with.
And, I do notice that in your screenshot the MusicBee button has its content misaligned:
Is it only the player panel font that you have set to a custom one, or others also?
The reason why that ProTunes skin doesn't show the issue for you is probably because it has "UseModernMenuButton"> set to "true".
I am guessing that if you use:
<element id="UseModernMenuButton">true</element>
in the Sample Skin, it will also display the black line for you?
Last Edit: May 09, 2024, 04:23:53 PM by hiccup
