Author Topic: 'Pop Pink' Skin  (Read 77447 times)
Rotem K.
               ------------------Pop Pink------------------
Skin File: http://www.mediafire.com/?mxuhmjcxx03mcdy
version 1.3.4324 or higher is required: Downloads Post
Those who use this skin as their default one, I recommend hitting the Notify button to get updates whenever they are available.
Hope you'll enjoy it!
Many thanks to Steven for all the help.
Rotem
           - DEPENDENT SKINS -
Those are skin who use the Pop Pink as a base to build on and color stuff differently.
Pop Blue
By Blinghound
Skin File
           - SKIN MODS -
paste those over the original element code
Color-Change-Mod: Find & Replace the numbers in the Pink column with those in whatever color you want
Pink     Bright Blue     Bright Green
    by Yourpassenger     by Yourpassenger
1228,89,122     20,205,255     0,206,99
2168,105,124     9,93,114     68,136,100
3255,119,133     19,205,253     0,212,101
4127,108,117     14,91,110     59,133,93
Thanks to the contributors!
Darker-Player-Panel Mod:
Find:          <!-- 76-->  <element id="Player.Background" bg="200,200,200" bg2="160,160,160" fg="60,60,60" bdr="160,160,160" />
Replace:    <!-- 76-->  <element id="Player.Background" bg="140,140,140" bg2="100,100,100" fg="60,60,60" bdr="140,140,140" />
Last Edit: November 03, 2011, 09:10:58 PM by Rotem K.
before you update to the new .exe linked to by RotemK, make sure you are already using version 1.2.3964 or above and have installed the latest internal web-browser version. See:
http://getmusicbee.com/forum/index.php?topic=551.msg10783#msg10783
Rotem K.
Updated XML: http://www.mediafire.com/?wmyx6xvdyrk8mjc
What changed:
- disabled buttons color adjusted.
- disabled text color adjusted.
Those who use this skin as their default one, I recommend hitting the Notify button to get updates when ever they are available.
I don't foresee any right now but still, I don't want anyone still using buggy old versions.
Last Edit: November 25, 2010, 03:03:10 PM by Rotem K.
john6555
Any chance you could reverse the star rating colors (so the star ratings are lighter gray, and the inactive stars darker)?
Also I would love it if you updated the Grey skin so the top menu is integrated into the window bar (next to the MB icon) like in the Pop pink skin.
Thanks again, great work!
north3rn.thund3r
Could you do the same for the Blue skin as far as the in-line menu goes?
Rotem K.
Thanks for the feedback John.
About the star rating colors, I honesty think that the way they are right now is better. I'll send you an image so you can be the judge of that.
Regarding the Smooth Grey skin and integrated the menu, we are working on it.
Quote from: north3rn.thund3r
I'll post an update on Cool Blue thread in a couple of days.
john6555
That makes sense in the track detail view because the 'unrated' stars are not shown. But in album art view it doesn't work that way:
Rotem K.
Ohhh, I see. sorry for the confusion, I thought you meant something else.
it doesn't suppose to look like that of course. I forgot all about the artwork view so it's a good thing you told me about this.
I've fixed that now, along with the tabs colors for lyrics and details on right side panel,
I'll fix the color of the button that controls the size of the artwork, and post an update.
Rotem
john6555
Rotem K, did you update the skin? I downloaded it again but didn't see any changes.
Rotem K.
Its being held up on account of a few more improvements then originally planed.
but be sure that when an update is available it will noted here on the thread.
Rotem K.
 -----------Image-----------
- First .EXE to support [all the skin elements] v1.2.3990: http://www.mediafire.com/?9ud2j3x9a4l0a8a
- Skin File: http://www.mediafire.com/?naa9vg5c1740c1b
changes:
- in line menu colors.
- AutoDj screen.
- spectrum visualization colors.
- FM Love icons, in player and in mini mode.
- artwork view rating issue.
- tabs colors for lyrics and details.
- few more color changes.
as always feedback is welcome.
Last Edit: December 04, 2010, 05:05:18 PM by Rotem K.
john6555
Thanks Rotem K, amazing skins! Right now Pop Pink is my favorite but I do like the updated Cool Blue and Smooth Grey too. Keep up the good work!
Rotem K.
Thanks John, glad to hear you like them :)
