Author Topic: Playlists not updating tracks that are moved  (Read 1769 times)
If a track in a static playlist moves, such as when it is added to the library and auto-organized, the playlist is not updated.  I end up with a (!) track pointing to the old location.
i just did a quick test for a file already in the library and all is fine.
Does it happen only when the file is not already in the library and then gets added to the library?
i cat say definitively that's the only time it happens, but that's when I'm seeing it, when i add a track (from the inbox) to the library
is this issue repeatable? I cant seem to reproduce it
If so, i would need to give you a debug version
Yes, it's very consistent.
There have been a couple of bugs in the past with the playlist file indexing so its possible: MusicBeeLibrary.pidx in the root musicbee music library folder is corrupted. Try deleting that file and hopefully it should start working again
Ok, I'll give that a try.  Thanks.
So far, it seems to be doing better since deleting the .pidx file.
