Author Topic: 'Pop Pink' Skin  (Read 77444 times)
Rotem K.
Yeah, i guess things changed with updates to the software. i'm still with v2.1.4770 in which the skin works as it was intended to.
Unfortunately, I no longer have the time to update my skins, though i'm sure it is manageable to anyone with enough will and time.
Sigma
No worries. It's still my favourite skin of all of the ones I've tried, and it's not like you need to look at that Preferences screen that often anyway.
@Sigma:
Find the following lines, and remove them.
<!-- 127-->  <element id="Controls.TabBody.Default" bg="120,120,120" fg="210,210,210" bdr="100,100,100" />
<!-- 127-->  <element id="Controls.TabBody.Disabled" bg="120,120,120" fg="210,210,210" bdr="100,100,100" />
The downside is that it will make the selected tab of "device" setting no longer differentiated from the background, but still it would be better than the current.
Last Edit: October 02, 2013, 12:48:11 AM by redwing
Sigma
Thanks! That looks better and I never use that Devices section of the settings anyway. :)
