Author Topic: 'Pop Pink' Skin  (Read 77448 times)
Rotem K.
VX
Sarge
Sure VX just PM me your e mail.
It's all Rotems good hard work, I just added some color differences.
VX
Thank you Sarge for the great skin ! Looks really cool  ;)
Maybe you could post in the topic, which entries should be modified to create the Skin form the Pop Pink, so that Rotem could include the screenshot and the modifications to the colored variants presented alongside with the original Pop Pink Skin.
Rotem, it looks like Your skin is the most 'productive' one on the forum  :D
Congrats  :)
Last Edit: February 11, 2011, 09:10:38 AM by VX
Sarge
http://img96.imageshack.us/i/popgreen.jpg/
I like the way the bottom pane is coloured. Sarge, could you share the skin when finished  ???
Glad you liked it. Rotem made a great skin to modify. it's a "Pop (your fav color here) Skin
Anyone who wants it can just PM me.
Rotem K.
carloscs
"Pop Pink Darker" and "Pop Blue" skin mods:
Note: needs latest MusicBee from this post: Dependent skins
"Pop Pink Darker.xml"
<root dependsOn="Pop Pink">
<colours id="Default">
<!-- 76-->  <element id="Player.Background" bg="140,140,140" bg2="100,100,100" fg="60,60,60" bdr="140,140,140" />
</colours>
</root>
"Pop Blue.xml"
<!-- 228,89,122 -->
<!-- 12-->  <element id="Menu.DropDown.Highlight" bg="87,112,230" />
<!-- 24-->  <element id="Panel.HeaderControl.Highlight" bg="87,112,230" fg="235,235,235" bdr="80,80,80" />
<!-- 30-->  <element id="Panel.Body.Highlight" bg="87,112,230" fg="255,255,255" />
<!-- 52-->  <element id="Content[TrackDetail].Body.Highlight" bg="87,112,230" fg="255,255,255" />
<!-- 97-->  <element id="PlayerSidebar.ProgressBar" bg="60,60,60" bdr="180,180,180" fg="87,112,230" />
<!-- 105-->  <element id="Controls.VerticalMenu.Highlight" bg="87,112,230" fg="255,255,255" />
<!-- 106-->  <element id="Controls.VerticalMenu.Lowlight" bg="87,112,230" fg="255,255,255" />
<!-- 168,105,124 -->
<!-- 31-->  <element id="Panel.Body.Lowlight" bg="116,148,201" fg="255,255,255" />
<!-- 53-->  <element id="Content[TrackDetail].Body.Lowlight" bg="116,148,201" fg="255,255,255" />
<!-- 65-->  <element id="Panel.StarRating.Highlight" fg="240,240,240" fg2="116,148,201" />
<!-- 67-->  <element id="Panel.NotLovedIcon.Highlight" fg="226,154,146" fg2="116,148,201" />
<!-- 255,119,133 -->
<!-- 78-->  <element id="Player.ProgressBar" bg="127,108,117" bdr="119,133,255" />
<!-- 127,108,117 -->
<!-- 78-->  <element id="Player.ProgressBar" bg="106,105,131" bdr="255,119,133" />
</colours>
</root>
VX
Thank you very much, carloscs  :) Could you provide some screenshots that would show the new look  ???
@Rotem
Perhaps you could edit the first posts about SKIN MODS taking into consideration the Dependent Skins  ???
Rotem K.
Yeah, I'll release the mods as dependent skins. haven't checked it yet but I hope a splash screen can be changed in a dependent skin as well.
Rotem K.
I've just check the new dependent skins, and I can't get it to work with a different splash.
Maybe I did something wrong, maybe it just doesn't work that way right now.
I've asked Steven about it. I'll post if there is any update.
Rotem K.
Wtf? now it does work. posted Pop Blue on the first page.
Thanks again to Blinghound for the mod.
VX
Carloscs, I used your Pop Blue mod, bud instead Pop Pink I made it dependent on Spotify B  (one of the best skins btw) :)
All I need to do was to change the name
<root dependsOn="Spotify B">
on the new skin file.
BTW, I noticed that the progress bar in mini player view is pink (not blue) when the mod is used with Spotify B. Is this correct ???
The dependent skins idea is just fantastic  :D
Rotem, your Pop Blue mod doesn't work for me. The skin file is not recognized by MB  :(
Last Edit: February 24, 2011, 02:18:19 PM by VX
Rotem K.
Can you try something for me?
leave only Pop Pink and Pop blue in the Skin Folder, move the rest of the skins to a different folder, then try to load Pop Blue.
let me know if it works then.
