Author Topic: Change taskbar player icons/buttons  (Read 3028 times)
Tybot
Is there any way to change the taskbar player icons/buttons, specifically the Last.fm Love? I've managed to change everything else connected to that function but I've been stuck for hours on the taskbar one. Any help would be greatly appreciated.
As you can see the red heart doesn't really fit in with the yellow star...
It's in Layout (2)
Tybot
It's in Layout (2)
Yes, the setting to show the button or not is located in Layout (2). But I'm talking about changing the way the icon looks. I'm starting to doubt that it's even possible.
I grabben a PNG image from google search, resized it to 13x13 @ 96 DPI and converted it to Base64 and pasted the code into my xml-skin and it works really well when using Album and Tracks-view, but if I switch to a filter that uses the Album Covers-view, I get and error message and MB crashes. I'm guessing there's something wrong with my images but I can't figure out what it is.
Error report:
MusicBee v3.1.6388.33699 (Win6.1), 4 jul 2017 20:04:
System.TypeInitializationException: The type initializer for '#=qhj_7br0WjXudE_6a1$Bng2Xpf3aCIjeua1Mx3PFU8n4=' threw an exception. ---> System.OutOfMemoryException: Out of memory.
   at System.Drawing.Bitmap.Clone(Rectangle rect, PixelFormat format)
   at MusicBee.MusicBeeMain.#=qUv5I5n1LuYf3ZQZCk_D1rIudyQlCdBj0LBmBMofI_HU=.#=q381up_D6Of1B3Q2WGwwwcmXNKcNssUtBXCTrcev2wyc=.#=qhj_7br0WjXudE_6a1$Bng2Xpf3aCIjeua1Mx3PFU8n4=..cctor()
   at MusicBee.MusicBeeMain.#=qUv5I5n1LuYf3ZQZCk_D1rIudyQlCdBj0LBmBMofI_HU=.#=q381up_D6Of1B3Q2WGwwwcmXNKcNssUtBXCTrcev2wyc=.#=qhj_7br0WjXudE_6a1$Bng2Xpf3aCIjeua1Mx3PFU8n4=..ctor(#=q381up_D6Of1B3Q2WGwwwcmXNKcNssUtBXCTrcev2wyc= #=qAdCGfanpAPqGxFza7V41Vw==)
   at MusicBee.MusicBeeMain.#=qUv5I5n1LuYf3ZQZCk_D1rIudyQlCdBj0LBmBMofI_HU=.#=q381up_D6Of1B3Q2WGwwwcmXNKcNssUtBXCTrcev2wyc=..ctor(#=qUv5I5n1LuYf3ZQZCk_D1rIudyQlCdBj0LBmBMofI_HU= #=qhYMr2VukZDLrFdAnDeQtBQ==)
   at MusicBee.MusicBeeMain.#=qUv5I5n1LuYf3ZQZCk_D1rIudyQlCdBj0LBmBMofI_HU=..ctor()
   at MusicBee.MusicBeeMain.#=q0tTcmJ5MkW_jrZKMPnL2vw==(#=qCSuBExOgmjexYHpGd0SER2OHmHeM4pitKfo_4kc7HdA= #=qMySQ_rN6I8Mzq8CTZrmIr_YDdqgwcA05yoWwXJz6afE=, Boolean #=qhGdRZGCqr$s68t3WsvWfCnDY5wkSp5hl8HMWZqdiy$8=, #=qy8sRYRrRlOb6zXHoX10gpg== #=qQYdV4RRGCqpuEvgrLtyiEw==, #=qIVabM1gH6mIFhU2A8JLqYTWVmoMQJn4AMYYl_P5upEU= #=qx9Hyi56Ke1vHiNyocpanKs3877Fi3T58SXtvEuZlol0=, Boolean #=qONgXhzxPBPKlO1W_g7AnIdPWh71JIwM$ca$ZQr32JJg=, #=q61jHC9Q6aD6$LlHlcZQ5yLfkkPG8zRLQXzrF$dsvgF8= #=qW0Tn2vSWTWnHzlFGteRsCw==, #=qKP67Ez6UI6fDJDb8IJJEoHPW4x_jZZKLv2cgGI2aTEc=[] #=qGtppiTo4M31Zxi_D4hzn$b3POSYzx4CWqzQgRp8uI4s=, Boolean #=qLJA7hy8fRndcnnHru8VMB2uR_nnfEUPA5edpb4g9sck=)
Ah, gotcha.  That's probably a skinning request.
Tybot
for the error, the icon needs to be 16x16px
however i have put in handling for that:
Oh my... You just solved a 48h battle in less than a minute. I can't thank you enough Steven. You're amazing!
