Author Topic: Changing/removing "Year (yyyy)" field from Expanded Panel  (Read 1389 times)
hadouken
I have an Original Year field set up to replicate a chronological order by Album Artist. However, the standard Year (yyyy) field remains in the header of the Expanded Panel.
Is there any way to replace the Year field with the Original Year field? Apologies if this is a simple answer; cannot find it for the life of me.
No, I think this would have to be a wishlist request. Or you can just swap the two fields.
hadouken
Thanks very much. Would rather keep the fields as per MusicBrainz Picard so will stick it on the wishlist.
