Author Topic: Info Problem  (Read 1185 times)
UltraPrime
Any thoughts on how to remedy this error on looking up profiles. Worked fine yesterday.
Screenshot
that should be addressed with v3.1 available from the first forum topic
UltraPrime
Thank you for the quick reply. I've updated from 3.0 build 5 to 3.1 and the problem is still there. Not a deal breaker but hope it's resolved soon as it's a feature I really like. It could be just on my end but I doubt it.
actually you need the 3.1 patch version:
UltraPrime
Thanks Steven. That did the trick and everything is working.   8)
