Author Topic: Jistme the NightBee 'Touch' edition  (Read 24046 times)
This one is identical to 'Jistme the NightBee', except for the player panel which has been redesigned for easier use on touchscreen tablets.
It has bigger buttons, wider scrollbars, and a larger area to tap and slide through the progress bar.
download Jistme the NightBee 'Touch' v3.x
This skin will only work and display as intended on MusicBee v3.1.6368 or higher.
Last Edit: June 11, 2022, 12:42:58 PM by hiccup
A request for members that have a touch tablet and are willing to try this out:
On my tablet, with this skin the buttons for 'shuffle' and 'repeat' don't refresh to the correct state after they have been clicked.
Also when the progress-bar is swiped to another position within the playing track, the small time position pop-up indicator stays on the screen instead of disappearing again.
Feedback if this happens to others too is appreciated.
WannaBee
Problem with the download link?
Flag:
"Secure Connection Failed
An error occurred during a connection to 1drv.ms. SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
    Please contact the website owners to inform them of this problem."
- Beautiful skin!
Last Edit: May 27, 2017, 07:48:20 PM by WannaBee
So, looking at your edited post, you have now succeeded?
The file is stored at Microsoft's OneDrive, so there's probably something odd with your browser or your security software.
Or Microsoft's OneDrive has been compromised, but that doesn't seem likely to me.
WannaBee
Sorry, no luck yet. Malware Bytes blocks the link. Could you please upload to another, just the same?
PM send
Updated, an issue is fixed where the player panel distorted when using larger fonts.
(the download link is in the start post)
Use at least MusicBee v3.1.6358
LamaPatate
I don't have those issue, but I have two others with this skin, I'm not using a tablet but I still prefer using this skin instead of the normal one because bigger buttons plus their position are way more satisfying regarding my tastes.
Here is the two problems I have:
1 - When the progression bar reach artist and song text, it covers them, making them completely gone a little after half the second (difficult to explain, but by looking to the progression bar in the screenshots, you will understand what I mean).
2 - When switching to "Now Playing" mode then using the "Large Album" view, if you activate the right panel for lyrics or biography, you will get a green background.
By the way, I love your work!
are you definitely using the very latest v3.1 (unzip and replace the existing musicbee files)
Thanks for reporting the issue (with screenshots), and for the appreciation LamaPatate!
The 'green' issue has been fixed.
(same download link as in the start post)
About the progress bar issue, I am sorry for not mentioning that indeed using the most recent MB v3.1 is a prerequisite for this skin.
I'll add that to the start post.
Be sure to let me know if you run into anything else!
LamaPatate
Oh, I'm sorry, I really though I had the latest build by now, I guess I was wrong, sorry again.
I feel stupid, but I have another problem now after updating MusicBee and downloading again your skin.
Now the progress bar is cut and isn't displayed correctly, look here what I get:
I already tried to switch from different skins, to remove and add again the player controls in the panels configuration menu, I also tried to place the progress bar in the bottom of the screen, I tried to see if scaling the windows change anything, but no matter what I do I can't figure out how to solve this.
Notice that the two previous problems I had are gone now, so thanks for that!
No need to doubt yourself. Concerning skins and skinning, both MusicBee and my skins are works in progress for v3.1 at the moment.
I updated the skin to (probably) fix the latest issue you mentioned. Same download link.
LamaPatate
What a relief to hear such thing, I though I was abusing your patience, that's why I was feeling stupid and everything, I'm happy to see I'm a pain to read for you.
Your fix works great, concerning me, there's no more problem, so thank you a lot for you consideration about my reports, but since I saw two other things by now I will report mostly for you since they aren't much a big deal for me.
1 - It isn't very important, but there's a slight problem (I think) with the beginning of the progress bar, sorry if it isn't a problem, I'm basing my opinion on your first screenshot where I don't see this, but maybe it's because I'm on a full HD screen or something, I don't know, here's the screenshot.
2 - By updating MusicBee, I saw now you can switch between the progress bar and a wave bar, but the wave bar is green.
Sorry to repeat it, but thanks for being that quick, effective and sympathetic in your answers, I appreciate a lot.
1: I will take a look at that probably this weekend.
    (You could activate 'Notify' for this topic, so you'll get a notification when I announce an update here.)
2: Should be fixed now.
This should be fixed by a correction in the latest MB v3.1 update. Let me know if you still see an issue in your setup.
