Author Topic: Importing data into MusicBee  (Read 6533 times)
Spicefly
Hi
I have a ton of playcount and track rating that I can export to an xml file.  I would like to import this into MusicBee but it looks to be using a bespoke format? and not for example a sqlite database?  I was hoping for a simple column I could have matched and imported  ;D
Any suggestions on how to import the data?
Cheers
manually parse your xml file, match xml data to tracks based on tags and write ratings to tracks. i'm afraid play counts are read-only in mb api.
i made a change a while ago so playcounts (14) can be written to
thanks, Steven. i'll change tag tools plugin according to this. the same for skip counts?
Both fields are already writable with your plugin.
i've already discovered this, but thanks anyway.
Another approach is to create an iTunes formatted XML file, from which MB can import the ratings and play counts only via the File/ Library/ Import command (or something like that)
Spicefly
Thanks for your help.  I did a proof of concept and managed to craft an iTunes XML file that MusicBee accepted and updated the library, so just in the process of writing a quick C# program to do the conversation of my source XML file to a suitable importable format.
Thanks for the steer :)
