Author Topic: Multiple "mood"/"occasion" support like genre has  (Read 2069 times)
EuroMIX
Forgive me if I've missed this anywhere, and this isn't a massive priority, but I could definitely see myself possibly using these tags for when I want to easily play music for a particular mood or occasion, but by default MusicBee only lets you pick one from each list.
I don't know if this is a tagging restriction, but I'd love a setup like genre where you can easily add multiple of each with a delimiter.
theta_wave
Did you try adding multiple moods with the same delimiter you used for genres in the mood field?
EuroMIX
The problem is that MusicBee has a great separate window for genre editing, but mood and occasion only have a single drop-down list each, and neither appears to make it easy to select more than one choice at a time. It would be nice if they had their own separate window like genre does so it would be easier to select more than one within the program.
i made a change recently where if you end the text with "; " then selecting another item from the drop-down appends to the text
EuroMIX
Can I ask when this change will be made available, if it's not already in the patchable 3.1 betas (I'll have to check)?
Edit: Just checked the latest version and it's there, thanks.
Last Edit: May 21, 2017, 04:59:07 PM by EuroMIX
