Author Topic: WASAPI buffer size set via ini file?  (Read 1185 times)
agisthos
I am using a HRT Music Streamer II+ DAC, which is notorious for not working correctly unless pre buffering is set to 25ms. Even 50ms wont work. It seems Musicbee has no options for allowing a buffer size less than 1 second.
So is there an ini file where I can set buffer size in milliseconds for WASAPI mode?
