Author Topic: Keep search results tabs after program restart  (Read 7860 times)
cosmingurau
  • Filmmaker
psychoadept told me that this is currently impossible, but he would support it! I would love to see it happen!  :-*
It would be extremely useful, as it would not require you to create a playlist for a listening session that you may want to return to in the subsequent days. A lot of the time, you don't want to make it "a permanent thing", but you also don't want to enter the search keywords every time you fire up MusicBee. Sometimes I keep multiple search tabs open and alternate between them (that is the beauty of having tabs, is it not? :D ) Of course, this whole thing could be a tickable checkbox in the settings.
Also, it would help a lot if the tab header for the search results would indicate the search keywords, like "Search:daft punk" or "Search:the weeknd starboy" or "Search: light never goes out". Or you could just leave the keywords, but make them italic/bold/underlined or something to differentiate them from "regular" tabs. 8) What say you, Steven? :D
MusicBee is a worthy successor to Winamp.  :D
Well, my support is just a +1 for the wish, but I do run into this problem frequently.  :)
Not sure when this was implemented, but it already exists both in the tab and with a mouse-over...
cosmingurau
  • Filmmaker
What version of MB are you running?
If not 3.1, I suggest you try patching to the latest. See my sig.
cosmingurau
  • Filmmaker
what shows up there depends on how you do the search
cosmingurau
  • Filmmaker
So, can we implement it, Steven? :) It really doesn't seem like something difficult to do, yet would be immensely helpful. :D
for the next update i have enhanced the tab header to show the text search that was used.
I will look at restoring the search filter for each tab next, however i expect i will only do this for text search filters
for the next update, search results for custom queries and text searches will restore on the next startup
Nicely done Steven. Thanks!
cosmingurau
  • Filmmaker
Thanks, Steven! Can't wait for said update! You the man, Steve!  :-*
