Author Topic: synching artwork  (Read 8848 times)
jes91354
First of all, great program!
I'm synching MP3 files to my Palm Centro as an MTP device using MusicBee 1.2.3875 (Win7 64-bit).  All the MP3 files already have artwork embedded, but this disappeared when the files were copied to the device.  Previously I had copied the files manually, and the artwork had shown up.
So I went to preferences/device, and saw the "do not copy artwork" radio button is selected.  Does this imply that MusicBee is stripping out the artwork as it copies the files?  I tried to change it to "embed artwork in the music file", but it won't allow me to select either of the other radio buttons.  Why is this?
Thanks,
John S.
the device must be reporting it doesnt support artwork.
I'll change it so it still allows you to embed artwork when this is the case
thats in the next beta on the weekly updates topic.
I changed the behavior when Artwork none is selected so that existing embeded artwork is untouched but external artwork will be copied across, whereas selected embed artwork will also embed any external artwork
Last Edit: November 15, 2010, 08:47:31 PM by Steven
jes91354
Thanks a lot, Steven.  I'll give it a try.
John S.
Last Edit: November 16, 2010, 02:39:48 PM by jes91354
jes91354
Works like a charm.
Thanks again,
John S.
