Author Topic: Where is "show track count for each item"?  (Read 3048 times)
markzzz
Hi all,
I've got the last version, but I'm not be able to show the number of tracks within each entry in the main panel. I can't find those preferences: http://musicbee.wikia.com/wiki/Layout_Preferences
Where are?
in the wiki example, the track count setting applies to library explorer. You can enable the library explorer by clicking the Arrange Panels button
markzzz
Not sure what you are suggesting to me.
I clicked on Arrange panel, and than Panel Settings on "left main panel". But it opens the same window, where there isn't the possibility to enable the track counter :(
I know what Steven's talking about, but I'm not sure what you're asking for.  You said in the main panel.  Can you give more info?
markzzz
Here for example:
I want the (#numberoftrackwithinthatentry).
I always used it in the past, I'm not able to reopen it...
You need to use the column browser instead of the thumbnail browser.  You can find it in the arrange panels screen.  Then, if it's not showing the count, right click the panel header (where it says "genre" or whatever, not where it says "browser")
markzzz
