Author Topic: Ctrl+Delete should delete entire words  (Read 2506 times)
Ayavaron
I've gotten into the habit of being able to press Ctrl+Delete (or Ctrl+Backspace) to delete entire words at once because it's supported in almost every text editor I've ever used and whenever I try to do it in MusicBee, I get a little tiny square. I tried to copy this square into here but it's not a supported character apparently. Would proper Ctrl+Delete support be difficult to add? It'd save me several seconds each time I wanted to delete a word and that'd probably add up to hours over the time I use the program.
i tried a few players and none are consistent about this. However I have updated the behavior to delete a word i believe is the latest standard behavior
Its in the next beta update on the weekly downloads
Ayavaron
You are an amazing software developer, sir. You are amazing at what you do.
