Hello
I'm new here ! I'm looking for the perfect music player, you know, the one that makes everything you want but doesn't exist :p
I'm testing several music players. MB is the best I found as a standalone player. A very nice player easy to use.
I would like to do two things :
-> be able to control a MB player on a "server" (could be a simple computer attached to an amp). The controlling device would be another computer (no android device - I saw there was an android remote for MB). I'd like to be able to rate and add songs to a playlist using that remote.
-> be able to play locally (on another device that the one attached to the amp) sons, from MB.
I think it could be possible with :
-> a centralized MB database. I should have MB installed on every device (for playing locally) but I should have the same ratings and playlists for every device. I could control the MB attached to an amp with a remote desktop (as far as I can have a centralized database, I can live with it)
-> a streaming MB on the server side. I could play files locally using streaming/transcoding and a client MB. Ratings and playlists will be stored on the server. I'll control the server using the MB client or a web interface.
Unfortunately, it doesn't work :
-> I didn't manage to use only one DB with two MB clients
-> at my knowledge, MB can't act as a server.
Can you help me ? Thank you :-)
