Author Topic: Getting MusicBee 3.1 to display classical work and movement tags like iTunes?  (Read 1471 times)
EuroMIX
Apologies if this is an annoying question, but I did use the search function and didn't find anything.
With the new work and movement tags available in 3.1 is there a a way to get tracks to appear like how iTunes handles them i.e. having the the different movements listed in an indented list below that work? I can't figure out how to do it, if it is currently possible.
The work and movement fields are available in 3.1.  You can use the subheader in album & tracks view to group tracks under a work header
