Author Topic: Artist information error  (Read 2825 times)
dareps
I recently came upon this error when trying to see Profile and More albums info in Music explorer - 'User authorization token expired', and this is line from error log - 4/16/2017 9:28:41 PM - The remote server returned an error: (401) Unauthorized.
Could you please tell me is there any way to fix it?
get the latest version from the first forum topic
Vitalina
Updating to latest version 3.1.6275 does not fixing the issue!
Same here! weird cause it was working fine few hrs ago.
am using 3.0.6276
Last Edit: April 29, 2017, 01:00:29 PM by Vitalina
I am getting the same error with latest build (3.1.6356).
in the AppData folder there is a file: xBoxTokens2.dat
could you PM me a link to it
try deleting it and it should cause MB to refresh the authorisation on next restart
Here's what I found.
There were both xBoxTokens.dat and xBoxTokens2.dat files.
I deleted the first file and renamed the second to xBoxTokens.dat, and now it's working again.
PMed both files.
xBoxTokens.dat is no longer used
although i think the issue is actually with Microsoft not following the UTC convention for token expiry value, i have put in some handling for unexpected authorisation expiry. I will post a link later after some more testing
http://www.mediafire.com/file/0a6dnb3xfo5wx5j/MusicBeeXBox.zip
Last Edit: May 28, 2017, 10:42:36 AM by Steven
CampNowhere
I am having the same issue, any chance of re-uploading the link, the current link you just posted is dead.
Just deleting xBoxTokens.dat & xBoxTokens2.dat files in your AppData folder will fix the issue.
The linked file is included in the latest 3.1 version from first forum topic.
