Author Topic: Syncing data from android app to PC  (Read 2007 times)
Genome
Hey peeps
I have a lot of music in my collection I want to sort/tag/give artwork but I don't particularly want to spend the time doing it when I'm home on my PC. However, I spend a lot of time getting to/from work and generally just play games/browse reddit etc during this time. I'd much rather use this time productively to work out my library, but I'm not sure if there's a mobile music app that will take all the tagging I do and faithfully sync it back up with musicbee on my PC.
Any suggestions?
You can't do this with MusicBee.  If you can copy directly from your library instead of syncing, you might be able to use something like resilio sync (or if you can connect as a USB device, free file sync) to update the files after they've been changed on the device.
