Author Topic: Cannot select "show album cover" for main player in preferences  (Read 1148 times)
EuroMIX
I can select every other option in this section, but for some reason "show album cover" cannot be selected at all. Is there a reason why?
I'm on a Windows 7 64-bit system running MusicBee 3.0.6276 using the Monaural skin, if that makes any difference.
custom (bitmap) skins cant support that. It will work with the musicbee default skin or some of the dark (non-metro) skins
EuroMIX
So it looks like the latest beta supports this feature for the skin(s) I'm using now, which is wonderful, but is there any way to reposition the artwork? I'd prefer it to be between the play, next, and previous buttons and the seek, title, artist, and time bar.
