Author Topic: Custom Views  (Read 1737 times)
Petrž
I created custom view from "Album Cover" view, and put column browser above it :)
but I found 2 problems:
1. Everytime I change "picture size" it also changes in default "Album Cover" view... So it is like they are not independent.
I found this in MusicBee Wiki, but i either don't understand it, or it is not working:
"If you don't want to make changes to the default version of a view, save a custom view BEFORE you configure it. Otherwise you will have to undo the changes to your default view later. "
I started to create my CustomView by saving setting to different view, but the 2 views are still dependent...
2. I would like to have more than 6 columns in "Column Browser" :) I still have a lot of space for other columns, but especially after I buy bigger monitor. Now it allows me to make just 6 columns
Here is my screenshot:
Last Edit: April 06, 2017, 12:57:19 PM by Petrž
C# Programmer
User Experience Expert
Perfectionist
6 columns is maximum at the moment. you could make a wishlist request for more columns.
