Author Topic: Playlist Explorer • Deleting an "Empty" Exported Playlist • MusicBee v3.1.6303  (Read 1714 times)
WannaBee
Hello everyone :)
Sometime ago, I exported a number of playlists- two of which are displayed under the heading "Exported" in the Playlist Explorer. Since then, I have split the MusicBee Music Library into several separate ones. Now, I am unable to delete any one of the two exported playlists. Even though neither one of the two lists is populated, upon deletion MusicBee flags an error, which reads: "The selected folder is not empty and cannot be deleted". I am quite certain that this result is all of my own doing, but could one of you perhaps please point out how to fix this?
Thank you.
its not clear what you are really doing.
If you are trying to delete "Exported" and that is a playlist folder then you need to delete the playlists in that folder first and then delete the folder.
You can easily do the same from windows explorer
WannaBee
I have inadvertently deleted the previous response which provided the solution.  :(
Just to say: Problem solved, and thank you Steven- I have now deleted the "Exported" folder via Windows Explorer.
Last Edit: April 06, 2017, 05:28:54 PM by WannaBee
