Author Topic: Windowed Mode Resizing Issue  (Read 1717 times)
Coogan
When I run MusicBee in windowed mode on my primary display, then resize the left the left & right sides to fit my screen then close the program, the next time I start MusicBee it show's on the wrong monitor. (my secondary screen)
My primary display is connected via DVI.  Secondary display is connected to HDMI.
Coogan
My MusicBee Version:
3.5.8878
could you send me 2 copies of your settings file (help/support/view settings)
- the first where MB starts up correctly
- the second after you restart and its in the wrong screen
not sure precisely what is going on but i have made a change for the next v3.1 update that i think will probably address the issue
Coogan
Thanks Steven.
I'm not ruling out that it could be a snapping issue within Windows 10.
Coogan
3.5.8878
Coogan
Thank you.
MusicBee now opens on the correct monitor.  (Tested multiple skins to verify that wasn't an issue as well)
Coogan  :)
3.5.8878
