Author Topic: Windows7 taskbar integration  (Read 2700 times)
MartinK
I have MB in my taskbar as I use it so often.  A lot of programmes fully integrate into the taskbar so that when you open the programme, it opens in the icon itself rather than opening another active icon.  It would be a nice feature to have just the one icon once the programme is openned.
Thanks
Martin
ferongr
I don't know what your problem is, but here, the dock icons works as they should. I have Musicbee pinned to the taskbar and it uses the same button after it's open.
MartinK
