Author Topic: The "Artist" tag is being concatenated into "Album Artist"  (Read 2543 times)
RonMoses
On albums where the Artist and Album Artist are different, MB is putting them together in the Album Artist tag, like this...
ID3 tag:
ARTIST: Jim Smith
ALBUM ARTIST: Various Artists
MusicBee:
ARTIST: Jim Smith
ALBUM ARTIST: Dexter Gordon; Various Artists
This causes a "Jim Smith" entry to appear in my Album Artists list, and I really don't want that. Is there a way to make MB stop doing this?
thanks!
ron
Avoid infestation. Rotate.
I think a screenshot would be more helpful here.  Where does the "Dexter Gordon" piece come in, for instance?
RonMoses
Crap. I'm sorry, I originally used Dexter Gordon as an example, then changed it to Jim Smith to "generic-ify" it, and didn't get all of them. Let me go back to Dexter:
ID3 tag:
MusicBee:
Now for the screen captures:
ID3 tag:
MusicBee:
As a result of that, I have a Dexter Gordon entry in my Album Artists list with one track on it. I hope that clears up the confusion I've created.  :)
That's helpful, thanks.  Can you show the Tag Inspector in MusicBee?  You can open it from within the Tag Editor.
RonMoses
I'm guessing this "TXXX/ENSEMBLE" thing has something to do with it, eh?
If that's actually embedded in my files I'll bet it's gonna be a joy to remove.
ron
Yep, I bet that's it.  It shouldn't be too hard to fix.  Select files and use the "remove tags" command in the tools menu to remove that tag.
RonMoses
You, sir, are a gentleman and a scholar. Thank you so much!
ron
