Author Topic: 3.1: Bug when stacking Playlist Directory using tabs  (Read 1607 times)
lostinsound
I currently have 3.1.6275 installed.
I'm having an issue when I try to stack the Playlist Directory and the Thumbnail Browser (or the Library Explorer) in the left main panel using tabs.
It looks fine at first with a tab for each one at the top, but when I click on the Playlist Directory tab the Thumbnail Browser tab disappears.
And then when I click on where the Thumbnail Browser tab used to be I get this error:
MusicBee v3.1.6275.38881 (Win10.0), 9 Mar 2017 9:50:
   at MusicBee.MusicBeeMain.#=qphhfrz8quSFk3hQmNF9m_k0OGeh56z9urEN722S_AE4=(#=q7HkBCArOA_dvN3ttBmmLtEZxVR66jenMhfsm_3_Rog0= #=qzkccbnTa5sBUlwzbrTEcgA==, Point #=qVlMlWV__4xmgFbswWYXZrA==, Int32 #=qqhU0c_p1OvNn_nPjcI6hSg==, Int32 #=qQ_YDkM85v4k83P0QxvO85w==, MouseButtons #=q3dJ7SVAR9uz96xp17kJK$g==)
   at MusicBee.MusicBeeMain.OnMouseClick(MouseEventArgs #=qEIL38o0E_JlXm6oZcGPR8A==)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at #=q3vtegDCaXY47Pi8lgPgEzLBEc65IvgHfXdWA7_7sRmI=.WndProc(Message& #=qfwwnxsVakcJBWcpbhKZ5Aw==)
   at MusicBee.MusicBeeMain.WndProc(Message& #=qVqehyXnRc_DyWgTWzTcXWg==)
i would need a link to your settings file (help/support/view settings)
lostinsound
