Author Topic: Progress bar stretching?  (Read 7703 times)
Alumni
To follow up this thread;
getmusicbee.com/forum/index.php?topic=16944.0
I'm trying to work out if it's possible to display the progress bar by repeating the image rather than stretching it. I tried setting the Y axis to -1 but it didn't seem to help.
My intent is to show a dotted line instead of the usual straight line.
if you still want to do this, would you mind posting a quick mockup so i can better understand what you want to achieve
Alumni
Sure, I was using a foobar skin as inspiration - see this screenshot and zoom in: http://orig00.deviantart.net/a31e/f/2017/053/1/3/eole_by_alibalicou-da2dav8.png
Notice how the unfilled progress bar is a dotted line rather than a solid line. I tried to achieve the same effect with skin creator, but no matter what I did it always came out as a solid line.
Last Edit: May 04, 2017, 05:50:38 AM by Alumni
this supports repeating of the progress bar background image:
https://www.dropbox.com/s/zpcatzggo6bmtgz/SkinCreator2.zip?dl=1
add the attribute named "repeat" to the images element and set it to true.
The repeating image width can be set as wide as you want but make sure the height is the same as the filler image
<element id="ProgressBar" parent="TrackInfoPanel">
  <images category="Background" stretchY1="5" stretchY2="5" repeat="true"
    default="Images\ProgressBar.png"
  <images category="Filler"
    default="Images\ProgressBarFill.png"
</element>
Last Edit: December 02, 2018, 09:20:52 PM by Steven
  • Heal The World
Steven...would it be possible to get this effect working with the progress bar filler image too?
This is what I had in mind for the skin that I'm working on...
At the moment, I can't accomplish something like this without the filler image (bold circle) taking on a repetitive pattern too.
Strength and Honour (2025)
can you send me a link to what you have so far and i can make an assessment of what would be involved
  • Heal The World
PM with link sent.
That looks nice.
This would provide for having a much less 'nervous' constantly moving progress bar.
PM with link sent.
thanks. I see what you mean now. I want to avoid enhancing the skin creator tool/ xmlc format but will have a look as whats involved with adding support in the skin xml file
to implement, create a single bitmap that contains images for each step in the progress bar. So if the repeated progress bar fill image is 10px in width then you need to create a single image 100px wide containing 10 images, one for each step. For example:
this image needs to as a base64 string to the skin file itself using element id=ProgressBarCustomFill
  <element id="ProgressBarCustomFill">
iVBORw0KGgoAAAANSUhEUgAAAGQAAAAPCAYAAAAS0WrNAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADr8AAA6/ATgFUyQAAACqSURBVFhHYxgFo2AUjIJRMApGwfAAjFAaDGRii/5DmQxPFvehyCGDgVKn0bTo/5fbF8BsQupANEgtMepA4EZd3KBQB+eAAgXZ8eh8GKC2OpDjkB2FTx2IhqklpA4EQGqJUQcCuCIPXR0IYAtsaqljgtKjYJCA0QgZZAAlS4GyN5RJlTKf2upA2X241yGjYBSMglEwCkYBVQC/jg0jCEO5OMGoOuyAcnUMDAAgCqhoReDS/wAAAABJRU5ErkJggg==
  </element>
by the way, i suggest you disable auto-colouring for the player panel: PlayerAutoColor
Last Edit: March 27, 2022, 06:20:26 AM by Steven
  • Heal The World
Steven, you're the man! It's working just as I'd imagined. Thanks a lot.
I'll be releasing the skin in the coming days. Just gotta polish a few things. (End result)
Last Edit: April 05, 2022, 02:08:53 PM by Mayibongwe
