Author Topic: locating songs in windows explorer  (Read 3245 times)
KizanDama
There seems to be a problem when I use the 'locate in windows explorer' option. My problem is that it doesn't locate all the selected files. It only locates one file in windows explorer.
gyfcat showing my problem
as you can see in the gyfcat, when the file explorer opens and if you look in the botton left, it says "1 file selected" when I actually selected all audio files. What is the cause of this? and how can I fix this?
Thanks
CritterMan
  • Now with FiiO M11!
To my knowledge, you can only locate one file at a time. Each selected file would need to be found one at a time, so if you had your entire library selected and tried to find them all you would tie up your computer with this task for a very long time with no way to cancel it. Plus, you'd have a new window for every single file found. Windows API limitation, if I'm not mistaken.
KizanDama
Ah, I see.
When I do this, it doesn't do that for me. Say, I selected a small batch of files to open in windows explorer, it only opens one window and only selects one file.
Is there something wrong with my Musicbee settings?
ma_t14
No, your MusicBee settings are fine. What CritterMan meant, is that this is expected behaviour and tried to explain how it would be inconvenient to have it any other way.
Any particular reason why you want to find where a selection of tracks are located? If you are trying to organize them in a single folder then you'd be better off using the file organizer which is intended for this kind of work.
KizanDama
So I can create copies of the tracks and make them into a zip file
djdalex
If that one cd or ep is tagged properly you only have to select one track.
Once you open the finder / folder all tracks from that cd or ep is in that folder.
Vinyl lover / Vinyl ripper / Vinyl cleaning / Digitizing addict / Audio repair / Audacity lover / Clickrepair.net lover / MusicBee Newbee
KizanDama
That doesn't work for me, @djdalex
It just opens the same one track in file explorer not the whole album.
you can select multiple tracks and drag'n'drop them to windows explorer window holding ctrl key (to copy, otherwise files will move).
