Author Topic: Music Scheduler  (Read 42273 times)
hurdaci
Hello,
First of all, thank you very much for the plugin. Although I manually open the programme during the time I schedule, the music does not play.
Example:
My schedule 08:00 - 08:30
At 08:10 I turn on the computer manually, I open the programme manually, but the music does not play automatically.
Can you help me with this.
hi, post a screenshot of the main plugin window. there are a couple unobvious options. i'll try to help.
p.s. i think you should turn on pc at 7:55 if your schedule starts at 8:00. but there may be some other issues too.
hurdaci
https://drive.google.com/file/d/1wzgDc9PxIzqtomxIfeNYgX-Bt0XZ1-V9/view?usp=sharing
Thank you for your help.
hurdaci
My dream is that even if I start the music manually, the automatic music switches off at the time I set.
I have a schedule between 07:00 and 08:10, at 07:10 I turn on the computer manually, I open the programme manually and start the music. Unfortunately, the music does not stop automatically at 08:10.
the only wrong thing i see on your screenshot is you have 2 schedules turned on simultaneously. yes, they have different start dates, but start dates are unchecked.
why do you wake up pc manually? just leave MB running and sleep pc. plugin will wake up pc by itself.
hurdaci
When I click on the dates, does the automatic music stop even if I open the manual programme?
But then I won't be able to make different music lists for different days?
Sometimes people other than the person in charge turn off the computer :( The person in charge is not always in a position to reach the computer. He describes it to someone else who doesn't know much about computers by phone.
Actually, what is important for me is that it stops automatically even if I start the music manually.
Last Edit: October 31, 2024, 10:04:40 AM by hurdaci
i didn't understand your questions, but all dates (actually days, my bad), times and duration acts only if checkboxes to the left of them are checked.
yes, of course. what do you expect if you start music manually? but what do you mean by "even if"?
hurdaci
Even if I start the music manually, the music does not stop automatically.
this won't work.
did you solve the problem? is plugin working now?
hurdaci
Yes Plugin works
but
When I manually open the programme in the middle of the planning time, the music does not switch off at the planning time.
Example: 07.00-08.00 music playback interval
When I switch on manually at 07.10, the music doesn't stop at 08.00.
hmm. i think i can fix it, but don't promise.
it's not obvious, but mentioned in readme, but just uncheck start time to if you want to start playing on MB startup.
i've changed font from MS Sans Serif 8.25 to Segoe UI 9. this is the only change:
https://www.mediafire.com/file/p9vze6k1vebcnvd/mb_MusicScheduler_latest.zip/file
hurdaci
hurdaci
see my below quoted by you
"hmm. i think i can fix it, but don't promise."
is that what you're talking about.
