Author Topic: Possible to customize which options / controls accessible in locked down mode?  (Read 1602 times)
tommik
I have found out that even after locking down the player there are still some options available which I would rather lock as well. For example I do not want the users to change replay gain playback settings but they can easily do it through Controls menu. I would like to hide these options (Replay gain off, Smart gain, Track gain only, Album gain only). Applies to other elements as well (like Equalizer, DSP Effects, Arrange panels button...).
НКВД
I agree. For example, you are @ friend's home, DJ-ing a party, then you go to get another cold one, someone creep up and next thing you know BOOM, them speakers 're blown up  :-X .
Much more serious consequences at the club. Or your kid at home turn RG off and broke your windows xD.
In all seriousness, this is good proposal. Volume control included.
i dont think that volume control should be disabled in lockdown mode, but probably all other options should.
